April 21, 2023 at 2:55 pm
Yanjing Zhao
SubscriberIn FDE sofware, we can directly get the effective mode area of a strip waveguide. However, for unsymmetric waveguide (width larger than height), how to get the effective mode dimension in both x and y axis?
April 21, 2023 at 5:50 pm
Guilin Sun
Ansys EmployeeAs long as FDE can simulate the waveguide mode, you should be able to calculate the mode area. At least you can export the data and calculate it by your self using script. I did not see any thing to prevent from doing this. Please try.
April 24, 2023 at 6:48 am
May 1, 2023 at 4:45 pm
Guilin Sun
Ansys Employeeyou can use
EE=getresult("mode1","E");
E2=EE.E2;
Ex=EE.Ex;
x=EE.x;
where Ex (and Ey,Ez) are 4D matrix of xyz and f.
then you can find x=0 intensity, such as
E_line=E2(find(x,0),:,:,:);
In your case, you can use E2(:,:,find(z,0),1) where z=EE.z
Please try.
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5290
3299
2469
