April 12, 2023 at 11:59 am
Vaibhav Deshmukh
SubscriberI am trying to match results of motor with measured data using motor cad.
I am getting efficiencies all around centric as opposed to actual data where efficiencies are right oriented ( high speed high efficiency). I matched almost all the parameters including no load losses.What could be the possible reason for this issue? What can i do match it perfectly? Kindly help me with this.
April 13, 2023 at 12:39 pm
Navya C
Ansys EmployeeHi Vaibhav,
Can you share screenshots of your results from motor cad and what is expected?
Navya
April 13, 2023 at 3:06 pm
May 2, 2023 at 2:21 pm
HDLI
Could you select a few points to compare input current? Are DQ axis current same between simulation or test data?
Howard
- License Error
- Workbench not opening
- Workbench error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
5180
3275
2453
