January 20, 2023 at 5:10 pm
Arvind Sinha
SubscriberI performed a structural analysis with some loading and then coupled that solution to eigenvalue bucking. Choose 2 modes. I get the following error. Any help will be appreciated.
*** ERROR *** CP = 285.625 TIME= 08:38:02
An unexpected error ( SIG$SEGV ) has occurred... ANSYS internal data
has been corrupted. ANSYS is unable to recover and will terminate.
Previously saved files are unaffected. Please send the data leading
to this operation to your technical support provider, as this will
allow ANSYS, Inc to improve the program.
Current ANSYS Traceback:
NxrefCreate_mp1
NxrefCreate
GNxrefCreate
BeamWarpCheck
pr7ver
CHECK
solvcl
ANSYS -
January 20, 2023 at 5:25 pm
Erik Kostson
Ansys EmployeeIt is not possible to know for sure, but this could be memory related (not enough Ram) - try reducing your model and run a smaller subpart.
If it is not a big model, try run with non-distributed mode on (so smp).
Erik
January 20, 2023 at 6:03 pm
Arvind Sinha
SubscriberMy desktop has 516 Gb of RAM ..
January 20, 2023 at 7:53 pm
Mike Rife
Ansys EmployeeHi Arvind
SEGV is a data error - could be data from memory, storage, network, etc. Which also means that nearly anything could be the cause i.e. bad input, bad hardware, program error etc. 516 GB of RAM is a lot, but still finite so there will be a limit to model size that you can solve...but I don't think that is the problem (for now). Are there any other warning or error messages in the output file you can share? If you are an Ansys customer can you please open an service request for this.
Mike
2066
1279
1096
457
