November 16, 2018 at 12:26 pm
Mary
Subscriberi am using eigenvalue buckling in concrete filled steel tube bt there is error message generated
1. The Unsymmetrical Newton-Raphson option is detected in Nonlinear Controls under Analysis Settings of upstream static structural. This setting is not supported for buckling analysis.? (bt my connection is frictional bond coefficient .25)
2.During the multiframe restart process, the .RDB file was found but the .R file was not found. Both files are required to perform the
multiframe restart. The ANTYPE,,RESTART command is ignored.(this is due the solving is taken place step by step?
any one help me?
November 16, 2018 at 3:02 pm
jpasquerell
Ansys Employeeeigenvalue buckling means only linear behavior is valid. frictional contact and most other contact is nonlinear.
apparently not enough solutions were completed. check the rescontrol settings.
November 17, 2018 at 6:47 pm
Mary
Subscriberkk thank you
Bt i have another erorr
1)SUBSPACE solver failure. The assembled stress stiffness matrix contains all zeroes. No load factor solution is possible.(why this happen?)
2156
1359
1150
462
