LS Dyna
LS Dyna
ELASTIC IMPACT ON A RIGID WALL
    • shivamr20
      greetings,
      i am trying to understand the mechanical apdl code for the problem "elastic impact of a rod on a rigid wall". this problem is solved in ansys verification manual 265. basically in this problem, a rod is striking a rigid wall at a velocity of 202.2 in/sec. so in order to do this transient analysis, i need to define this velocity as an initial condition for all the nodes of the rod. As far as I understand, the code should be "IC,ALL,VELX,,202.2" where all are the nodes of the rod. But when I looked at the verification manual code for this problem, the initial condition was defined as "IC,ALL,UX,,202.2". I dont understand why UX and not VELX. we need to define velocity right? i would truly appreciate any help on this.
    • Erik Kostson
      Hi
      We can not see this (IC,ALL,UX,,202.2). Could you let us know where you saw this (help manual, and which release, etc.)?
      VM265 issues correctly for the initial velocity say in the help manual (2022 R1/current release:):
      IC,ALL,VELX,202.2
      • shivamr20
        ANSYS MECHANICAL APDL VERIFICATION MANUAL, NOVEMBER 2013, RELEASE 15.0
    • shivamr20
      HI
      this was on ANSYS MECHANICAL APDL VERIFICATION MANUAL – NOVEMBER 2013, RELEASE 15.0. Problem VM265. By the way, where can I get the latest release?
    • shivamr20
      ok, I got the latesh manual. It says "IC,ALL,VELX,202.2". Thank you
Viewing 3 reply threads
