December 11, 2019 at 9:21 am
m.caragiuli
SubscriberHi,
I've used tension experimental data about a hyperelastic material modeled through Ogden 2nd order material. By looking at the deformation and stress results I've noticed that the material exhibits compression in some regions, thus I would like to know what is the behaviour it follows in compression if it has only tension data? Is it a symmetric behaviour? I've tried to add also the compression data and the results are the same for the stress.
3345
2471
