Electric Field with Plane121
    • patrick123
      I'm having an issue that I'm no longer getting an electric field calculated when using "plane121" elements in a simple 2D model in Mechanical APDL. The same code worked in the previous version of ansys student, but not in the most recent one. I get the error that "The requested EF data is not available. The PLNSOL command is ignored." Is there some command I now have to pass to ask it to calculate electric field?
Viewing 0 reply threads
