September 9, 2022 at 5:38 pm
junaed.buet
SubscriberHello, I use Ansys Electronics Desktop software 2022. However the Electric Machines Design Toolkit is not showing in Toolkit of the maxwell . Where I can download it and add with my ansys software. If possible can one mail me the toolkit .My mail id
junaed.buet@gmail.com
September 12, 2022 at 6:15 am
Vinay_G
SubscriberHello,
You can get it by following:Maxwell -> View -> ACT extensions -> In side column, check in launch wizards, if there is no Machine Toolkit then add machine tool kit from manage extensions from the previous menu.
September 14, 2022 at 12:35 pm
Anchal Singh
Ansys EmployeeHello @junaed.buet,
Vinay_G is correct. You can add this extension from the 'Manage Extensions' menu if it is not there in the 'Launch Wizard' menu.
Thanks
Anchal
- Maxwell, HFSS or Q3D?
- Error
2642
2110
1335
1112
461
