February 14, 2022 at 6:45 am
sampathkumar
SubscriberI designed a motor and I simulated it in the MotorCAD tool. I designed the motor for peak power rating but I am not getting the required peak values. May I know the reason behind this
February 15, 2022 at 10:19 amNavya C
What are the "peak values" you are talking about?
There could be N number of design reasons why you did not get the required power from the motor. Like the core saturation, not enough voltage due to high back emf, etc.. As an Ansys employee, I cannot help you with the design but we can surely help you with anything related to the tool use if you can provide more specific data along with some screenshots.
Regards Navya
- Maxwell, HFSS or Q3D?
- Error
3694
2564
1765
1236
592
