March 1, 2022 at 2:21 am
rhawns4567
SubscriberHi,
I wonder if there is a way to check the electrical characteristics of OLED.
I'll wait for your reply.
Thank you.
March 2, 2022 at 6:44 pmKhashayar Ghaffari
Ansys EmployeeHi Thank you for reaching out. What materials and electrical characteristic are you interested in? Typically, the electrical simulation of OLEDs in CHARGE, requires simulation of wide bandgap materials. Currently obtaining convergence for these materials is challenging, preventing an electrical simulation of OLEDs to be run.
Best regards
- Error on Lumerical device
2656
2120
1347
1118
461
