August 15, 2017 at 2:38 pm
joshua.wallace
Ansys EmployeeIn this tutorial, a current runs though a wire. This results in a temperature increase in the wire which is calculated. See the attached file for the tutorial of this problem.
- I’m a starter
- YouTube tutorial files
- Fluid Flow – Lid Driven Cavity
- Thermal – Heat Conduction in a Cylinder
- Fluid Flow – Turbulent Flow Over a Backward Facing Step
- Fluid Flow – Taylor-Couette Flow between Rotating Cylinders
- Magnetics-Permanent Magnetic Circuit with Air Gap
- The project files directory doesn’t exist
- vibration
- Process ‘3dedy’ terminated abnormally. It may have run out of memory or could have been killed by..
2524
2066
1283
1096
459
