February 11, 2022 at 6:49 am
Oriol
SubscriberHi you all!
I am working on a simulation in which my idea is to see the displacement of an electrical contact when you apply a force on it.
February 11, 2022 at 4:37 pmAshish Khemka
Please use a revolute joint instead of using frictionless support and cylindrical support. Also, force imbalance of 1N will give rigid body error. Instead, apply displacement and then find the force reaction at the displacement b.c. to see what force will cause the applied displacement.
Regards Ashish Khemka
February 14, 2022 at 7:45 amOriol
Your suggestion worked well! Thanks!
Even though, I got very high values of the force reaction for a 5,5N simulating a spring load...
I was wondering how can I apply the force reaction using this other approach:
I cannot find any option from the force reaction probe to work on the highlighted yellow area.
Thanks for your help!
February 14, 2022 at 9:03 amFebruary 14, 2022 at 10:56 ampeteroznewman
SubscriberThe high force you measure moving the surface D in the Z direction is because that BC keeps the surface flat, but in reality, that surface rotates as it moves to open the contact.
Instead of using a Displacement on the surface D, use a Remote Displacement, Behavior = Deformable and enter the Z displacement leaving all others Free. Now the surface can rotate as it deforms. You will find the Reaction force from the Remote Displacement is lower.
Once you have a Remote Displacement (or plain Displacement) as a BC replacing a Force, you no longer need the other side of the contact. Suppress that part, the solution will be faster.
You should also try creating elements half the size, or smaller to get 2 elements through the thickness. This may lower the force further.
Viewing 4 reply threads- You must be logged in to reply to this topic.
3744
2573
1803
1236
594
