Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
Electrical Transformer- PWM in primary winding
    • andrein13
      The primary winding of a transformer can be supplied with electrical voltage in the form of a pulse (for exemple rectangular signal similar to the PWM signal)?nThank you very much!n
    • KR
      Administrator
      Hello,nQuick clarification - which tool are you using?nThank you.nKarthikn
    • andrein13
      Hello,nAnsoft Maxwell 14.0.n
    • KR
      Administrator
      I moved this discussion to the 'Electronics' category for streamlining with our products. We should be responding to this very soon. nThank you.nKarthikn
    • icellb1
      Hi, ,nYou can type in pwl(datasetname, time) or pwl_periodic(datasetname, time) function to create user specified dataset to define the waveform. Please see Maxwell online help: Maxwell Help > Working with Maxwell Projects and Designs > Working with Variables > Using Piecewise Linear Functions in Expressionsn
    • SinghVipin
      Hloo Sir ,nPlease help me to make a simplore circuit which is basically pwm generation based on rotor position.nI don't have any idea in simplorer. I have maxwell 2D model and i want to run this using rotor position. this is switched reluctance motor control.n
Viewing 5 reply threads
  • The topic ‘Electrical Transformer- PWM in primary winding’ is closed to new replies.
