November 8, 2021 at 6:44 pm
ha_nguyen3
SubscriberHello,
I want to perform an electro-thermal analysis using either Icepak or mechanical coupled with HFSS in AEDT. In previous post, I was told that the results of Icepak and Mechanical-thermal should be in line if they have similar setup. https://forum.ansys.com/discussion/comment/137023#Comment_137023
My model consists of biological tissues. And since I don't know which tool is suitable for my model, I run thermal analysis on both Icepak and Mechanical. The ambient temperature for both simulations is 24C.
For Icepak:
- I calculated surface loss and volume loss on HFSS using Field Calculator
- Assigned the opening for 6 faces on the Air box
- Assign thermal < EMloss to all objects
- Set up Analysis
- Generated mesh and ran the simulation
For Mechanical Thermal:
- Assigned boundary
- Assigned excitation < EMloss for all objects
- Linked the analysis to HFSS
There is no significant difference in the setup for both Icepak and mechanical. The only difference is that convection is used as a boundary for one of the object in Mechanical, and an opening is assigned in Icepak.
However, the results of Icepak and Mechanical are not similar to each other. Also, I want to add on metabolic rate (heat generation) and blood perfusion (heat removal) for my model, but I can't find these features in Icepak or mechanical.
P/s: I can't find examples of thermal analysis on human or animal models anywhere (even on Ansys Learning Hub). I have been referring to Waveguide Filter available on AEDT as an example of Icepak coupled with HFSS.
Temperature Map from Icepak
November 30, 2021 at 5:59 pmPraneeth
Ansys EmployeeHi The response to this question is being provided through other channel and hence closing the thread.
All the very best.
February 23, 2022 at 7:24 pmshashank1
I have similar issue too. Did you figure out how to define initial temperatures to biological tissues in Icepack.
- Maxwell, HFSS or Q3D?
- Error
2564
2068
1289
1106
459
