August 10, 2019 at 2:24 pm
p43kumar
SubscriberI’m hoping to model a system supporting Electrodynamic suspension in the Transient Module in Ansys Ansoft Maxwell (2D). I have a 2 coil system with a plate suspended over the levitator setup. I supply a sinusoidal current with a frequency of 1000 Hz and a current of 3 A in opposite direction to the two coils. (Image of model provided below)
Figure 1: Overall 3D EDS System
Figure 2: 2D Model of the Levitator system
I’m hoping to leave the plate free to move in the vertical direction. This movement (a function of time) would be a result of the time varying Lorentz force generated. I was wondering if the ANSYS Ansoft Maxwell 2/3D module was capable of supporting this simulation?
Thanks al.
- Maxwell, HFSS or Q3D?
- Error
2534
2066
1285
1104
459
