September 4, 2018 at 6:55 pm
DmitriiKruglov
SubscriberHello,
For some reason HFSS does too many passes, beyond what I've been setting up in the solutions setup. It carries out pass after pass until there are too many nodes for the solver and it returns "Solver out of memory" error. Is there something I am doing wrong?
Thank you,
Dmitrii
September 5, 2018 at 4:48 pm
Karthik R
AdministratorHello,
I moved your question to the 'Electromagnetics' thread to ensure it gets the traction it deserves.
Thank you.
Best Regards,
Karthik
September 5, 2018 at 8:19 pm
asamaiyar
SubscriberHi Dimitri,
This may happen due to following reasons:
1) You have a high resonant structure at your meshing frequency (try to mesh at slightly higher frequency and run discrete frequency sweep).
2) You S-Parameter (or delta energy in some cases) convergence criteria is very low. Default is 0.02. I sometimes go for 0.01 when I really want to push the mesh.
3) Try mixed order basis function instead of first order.
Also, what is your definition of "too many passes". I usually set my default max to 20. (Sometime 40 based on complexity of model).
How much RAM do you have? Sometimes the computer in not powerful enough (in terms of RAM) to solve the level of complexity of the problem. So you might have to try this on a bigger machine (more RAM).
Hope this helps.
Aman
September 13, 2018 at 9:14 pm
DmitriiKruglov
SubscriberHi Aman,
Thank you for your reply! I am sorry for my late response, I was sick for couple of days.
"Too many passes" means that I set this number to be, let's say, 6, but the software keeps refining the mesh until it drives itself out of memory. We have 32 gb ram, so I was hoping it is not the problem.
1) This is very possible, I am looking at it right now. I indeed was looking at the field distribution around the resonator at the resonant frequency.
2) I set the S-parameter to be 0.1, which is rather big than small.
3) Will do!
I will mark the thread "solved" if the frequency de-tuning or mixed order basis functions will help. Thanks!
Dmitrii
September 13, 2018 at 10:29 pm
DmitriiKruglov
SubscriberDe-tuning the frequency and setting the mixed-order functions solved the problem!
September 13, 2018 at 10:33 pm
asamaiyar
SubscriberI must also mention that it is highly recommended that you mesh your model at resonant frequency for most accurate results. De-tuning is just a quick workaround to roughly check if you are getting what you kind of expect.
September 15, 2018 at 5:18 pm
asimghalib
SubscriberHi everyone.
Currently, I am running a CMA analysis (HFSS) on a 32 GB RAM machine. Still, I am getting the "Out of memory" message. I made the adaptive passes to 1 but still, I am getting this message. any idea how to fix it?
thanks in advance
September 16, 2018 at 9:33 pm
asamaiyar
SubscriberI have never performed CMA on HFSS. But if you are performing this analysis using eigenmode solver, then one way to same time and memory is to request less number of modes. Please start a new discussion thread if you want the opinion from a wider audience.
--AS
- Maxwell, HFSS or Q3D?
- Error
2600
2088
1319
1108
459
