August 28, 2019 at 8:52 am
August 28, 2019 at 5:08 pm
tsiriaks
Ansys Employeedo you get the same issue if you use the sample projects that come with the AnsysEM installation (File -> Open Examples -> RMxprt) ?
August 29, 2019 at 8:48 am
NaplonDennis
Subscriberyes, it happens
September 5, 2019 at 9:45 pm
tsiriaks
Ansys Employeewhat if you try other design type like HFSS, Maxwell 2D , etc. ?
you can try renaming your C:UsersusernameDocumentsAnsoft folder to anything else
also try setting your temp directory to be under C:Temp . You can change this from AEDT GUI -> Tools -> Options -> General Options -> Directories
If these don't help, I suspect issue is related to graphics.
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2522
2064
1279
1094
456
