November 7, 2020 at 1:14 pm
krada
SubscriberNovember 18, 2020 at 3:11 amAshish Khemka
Forum ModeratornnFor orienting an element coordinate system to a global one, please refer the following post:nnRegards,nAshish KhemkanNovember 18, 2020 at 1:56 pmkrada
SubscriberThank you very much for your answer. i have managed to set up ESYS correctly. but then after error of element distortion occurs. i know that coarse mesh is one of the reason. but if i model my spring in a such way that it has stiffness in tension then it is working fine. and i got solution converged. but i want to model spring in compression only. nmy keyopts of Combin element are KO(1)=0, KO(2) = 0 and KO(4) = 1 moreover i have set Force-deflection points in third quadrant and in first quadrant for compressive and tensile cases respectively.nIt would be very helpful if you can guide me. nViewing 2 reply threads- You must be logged in to reply to this topic.
- A solver pivot warning or error has been detected
8798
4658
3151
1680
1470
