June 10, 2020 at 2:45 pm
kugg2116
SubscriberWhen I used a single element to test the model JH2 (mat 110) in LS-DYNA (see k file below), the element failed abruptly at some point before the failure criterion was met. This might lead to an underestimated load bearing capacity. I have tried different element formulation, hourglass control, but still couldn’t fix it.
The stress curve is shown below in green, the red curve is pressure. The second figure is the result I got from ABAQUS for the same problem. As you can see, initially, the two results are very close. The difference lies in that the element in LS-DYNA failed around 0.3s.
June 10, 2020 at 3:02 pm
kugg2116
Subscriber*KEYWORD
*TITLE
*CONTROL_TERMINATION
3.0 0 0.0 0.01.000000E8 0
*CONTROL_TIMESTEP
0.0 0.6 0 0.0 0.0 0 0 0
0.0 0 0 0.0
*DATABASE_GLSTAT
0.002 3 0 1
*DATABASE_MATSUM
0.02 0 0 1
*DATABASE_SLEOUT
0.02 3 0 1
*DATABASE_BINARY_D3PLOT
0.002 0 0 0 0
0
*BOUNDARY_PRESCRIBED_MOTION_SET
2 3 2 1 1.0 01.00000E28 0.0
*BOUNDARY_SPC_SET_ID
0Bottom
1 0 1 1 1 1 1 1
*SET_NODE_LIST_TITLE
Bottom
1 0.0 0.0 0.0 0.0MECH
4 1 2 3 0 0 0 0
0Top
2 0 0 0 0 0 0 0
Top
2 0.0 0.0 0.0 0.0MECH
6 5 8 7 0 0 0 0
*PART
Single_Elem_JH2
3 2 1 0 1 0 0 0
*SECTION_SOLID_TITLE
Solid section EQ1 RI
2 1 0
*MAT_JOHNSON_HOLMQUIST_CERAMICS_TITLE
SiC_abaqusExample
13.21500E-9 193000.0 0.96 0.35 0.009 1.0 0.65
1.0 750.0 0.0 11700.0 5130.0 1.0
0.48 0.48 220000.0 361000.0 0.0 0.2
*HOURGLASS
1 4 0.03 0 1.5 0.06 0.1 0.1
*DEFINE_CURVE_TITLE
Downward_displacement
1 0 1.0 1.0 0.0 0.0 0 0
0.0 0.0
1.0 -5.0
2.0 0.0
3.0 5.0
*DAMPING_GLOBAL
0 0.1 0.0 0.0 0.0 0.0 0.0 0.0
*ELEMENT_SOLID
1 3 1 2 3 4 5 6 7 8
*NODE
1 0.0 0.0 0.0 0 0
2 100.0 0.0 0.0 0 0
3 100.0 100.0 0.0 0 0
4 0.0 100.0 0.0 0 0
5 0.0 0.0 100.0 0 0
6 100.0 0.0 100.0 0 0
7 100.0 100.0 100.0 0 0
8 0.0 100.0 100.0 0 0
*END
3720
2570
1783
1236
594
