Element formulation reg
    • srira
      I have performed a 2D plane strain orthogonal cutting simulation in Ansys workbench/explicit dynamics. I modelled the workpiece as a square surface and meshed with Quadrilateral elements. I used the default conditions in analysis settings. Simulation completed normally.
      1] how to check the element name, When I accessed the report, it says quadrilateral elements.
      2]Also, how to know what kind of formulation was used to solve this model and how many integration points in the element formulation.
      Thanks.
    • Wenlong
      1) In Explicit Dynamics, only linear element are used, so if you know the element shape, you will know how many nodes in the elements.
      2) Accordeding to the recommended practices (https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/exd_ag/ds_rec_pre_str_exd.html?q=explicit%20reduced%20integration%20point), reduced integration point is used for brick elements.
      Others please chime in to provide more information regarding 2D elements.
      Wenlong
    • srira
      Thanks for the information, but the provided link demands the login credentials
    • Wenlong
      ================ Note ====================
      If you have trouble opening the links I attached, please see the first useful link below
      Useful Links
    • srira
      Thank you very much your timely help sir.
Viewing 4 reply threads
