Ansys Free Student Software
Element has excessive distortion.
    • up1057819
      Hello everyone,
      I am running a large deflection analysis with mechanical Apdl ( NLGEOM, ON). As soon as the loading initiates the solution collapses and I get an error message that a particular element has exceeded distortion. When I check the elements ( SHELL181 Quad node element)  deformation it changes from a rectangular shape to a completely irregular one.
       I have tried to reduce the time step and increase the number of substeps but nothing worked.
      Why this error occurs?
    • peteroznewman
      Does it solve with NLGEOM turned off?
      You might have a mistake in the model.  Check the magnitude of the loads and check the values of the material properties. Check the thickness property of the shell element.  Reduce the load by a factor of 10^3 and try that. Reduce the load by a factor of 10^6 and try that.
    • up1057819
      Yes, it solves when the NLGEOM is off. I tried that but didn't work.If the problem is related to the connection of the elements how could I solve for that?
    • peteroznewman
      If it solves as a linear solution, it is unlikely to be an issue with element connectivity.
      Please reply with images of the mesh, load and boundary conditions.
    • up1057819
      Here is an image of the model. The seen are restrained in ux,uy, and the first node of the row in ux,uy,uz (only one node is restrained in all three degrees of freedom). The whole structure is meshed witth an element size 0.5 ( esize=0.5). The load is applied in a form of a displacement( seen in the second picture) firstly the nodes are given a displacement equal to 10mm in the uy direction(vertical) and then in the -ux equal to 0.5. this is done in order to simulate shear stress in the core.The model is connected with AOVLAP command. Hope this is enough for you.
    • peteroznewman
      What is the goal or purpose of this analysis?  What is it that you want the results to tell you?  Are you looking to calculate the shear modulus of the core in a specific direction?
      In the graphics, I can see a row of ux, uy constraints on one edge of the top facesheet and I understand the corner node is constrained in x,y, and z. Having one straight line of nodes like that creates a hinge.
      In the second image, it's not clear which nodes are given a displacement. I also don't know how thick is the core compared with the 10 mm displacement you mentioned.
      I recommend switching to applied forces and don't use any applied displacements.
    • up1057819
      The purpose of the analysis is to examine some shear stresses. The 10 mm is the same as the thick of the core. I cannot use force because I don't know the magnitude
    • peteroznewman
      A 10 mm thick displacement of the bottom facesheet relative to the top facesheet with a 10 mm thick core is an absurdly large amount.  What is core material and wall thickness?  What is the facesheet material and thickness?
      Is the core manufactured by corrigating and bonding two thin sheets together? That creates a double thick wall in one direction. Did you do that in your model?
      Here is the test apparatus from ASTM C273 -11 Standard Test Method for Shear Properties of Sandwich Core Material.
      If you don't want to switch to Force, I recommend that you select the row of nodes on the bottom facesheet at the opposite end of the sandwich from the row that has the x,y constraints on the top face sheet. Use a Displacement of Y=0 to prevent rotation about the first edge.  Is the sample 50 mm long?  In that case, 1% strain would be 0.5 mm. Use a Displacement of X= -0.5 mm to those bottom edge nodes to put the facesheets into tension at each end. Use 100 initial and minimum substeps, 1000 substeps maximum, in the solution.
Viewing 7 reply threads
