Preprocessing
Preprocessing
Element Mid-Side Nodes Ansys 19
    • nohapeter
      How can I drop the element mid-side nodes in Ansys 19 which was possible by looking into: mesh- details of mesh - advanced,  in previous versions of Ansys?
      Thanks
      Noha
    • peteroznewman
      Click on the Mesh title in the outline in Mechanical.
      In the Defaults portion is Element Order which can be set to Linear to drop mid-side nodes or to Quadratic for what used to be called mid-side nodes kept.
    • ANSYSRUSHI
      Why do we need to drop Element midside nodes in Explicit dynamics? Also, what will happen if we don't drop it?
    • peteroznewman
      Explicit solver was written to use linear elements. If you have quadratic elements you will get an error.
    • ANSYSRUSHI
      Got It sir thank you for your explanation.
    • packhamg
      Hi Peter,
       My defaults does not have element order tab. Where can I find it?
      Kind regards, George
Viewing 5 reply threads
