May 18, 2022 at 5:09 pm
joedson_almeida
SubscriberHello averyone,
I make a geometry in plane x,y,z with elements Pipe289 (straight pipe) and ELBOW290 (bend) in Ansys APDL. How to define internal temperature (TIN(I), external temperature (TOUT(I)) and TIN(J) and TOU(J) ? In this case, I use the same thermal expansion coeficient.
May 23, 2022 at 11:54 amAshish Khemka
Please see if the following link helps:
PIPE289 (ansys.com)
How to access the ANSYS Online Help ÔÇö Ansys Learning Forum
Regards Ashish Khemka
Trending discussions- How do I make a chart with multiple material parameters on y-axis?
- Invalid Assignment error
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- Ansys material damage
3754
2573
1823
1242
598
