Element Table Error in Workbench
    • j100
      I have run a transient model of a metal beam in Workbench. I have input the following commands into the solution
      with the purpose of creating an element table.
      etable, table1, temp
      etable,table2, volu
      pretab,table1,table2
      However, in the post 1 output, I have run into the following errors.
      STORE TABLE1   FROM ITEM=TEMP  FOR ALL SELECTED ELEMENTS
       *** WARNING ***                         CP =       0.266   TIME= 13:567
       The degree of freedom solution is not available.  The ETABLE command
       is ignored.
       STORE TABLE2   FROM ITEM=VOLU  FOR ALL SELECTED ELEMENTS
       *** WARNING ***                         CP =       0.297   TIME= 13:567
       Item VOLU has not been stored in the database.  The ETABLE command is
       ignored.
      How could I fix these and display element temperature and volume?
      Thank you
Viewing 0 reply threads
