Preprocessing
Preprocessing
Elements are not visible, is this a Graphic problem
    • Cpwtub
      Dear All,
      I tried to produce INFIN elements in APDL. As the fist step I checked with the same example code given under EINFIN command reference( ANSYS online). picture attached----
       Even after using the same command, APDL showing following . Some elements are not visible. Is this a graphic problem ?? Do anyone know the reason
      Thank you
      Appreciate it a lot
Viewing 0 reply threads
