May 18, 2023 at 10:54 am
Nicola Menga
SubscriberHello.
I'm trying to simulate the flow in a nozzle.
I have a question: it is possible in fluent to disable the friction with the walls of the nozzle?
Thank you. 😀 -
May 18, 2023 at 2:37 pm
Ansys EmployeeIt is. Look in the wall boundary condition panel.Â
May 19, 2023 at 8:19 am
Nicola Menga
SubscriberHello.
Thank you for the suggestion.
Yes, from the "Shear condition" section of the wall boundary condition panel, by setting it on "Specified shear" and setting each value equal to 0, the desired condition should occur.
May 18, 2023 at 5:47 pm
May 19, 2023 at 8:20 am
Nicola Menga
SubscriberOh, thank you 😬
5454
3419
2473
1310
1022
