Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
EMC PCB – error importing .brd
    • andrea080690
      Hello, I would like to analyze the electromagnetic interferences in a PCB. I have the PCB in EAGLE and I have the .brd file. When I go to ANSYS electronics and I import the file .brd an erro occur. C/User/Documents/Ansoft/file.aedb/layout.def has a wrong route. nAny help?n
    • Praneeth
      Hello Array,
      Please share the screen capture of the messenger window regarding this error to help us serve you better. You can use "upload image" option to attach any image relating to this. In addition, you can also check whether you have write permission to the file ("file.aedb") or check whether the mentioned file path is valid or not.
      All the best.
      Best Regards,
    • andrea080690
      The bunner says it contain a routh of acces incorrect, but I have just the file .brd
    • VivekKamble
      This error can occur if you don't have feature available in the license file to read .brd file. Also this feature comes with Electronics enterprise licensing.
      you can try with other other file format.
      Please check the box in general options tab as follows,
      Please go to Tools -> Options-> General Options -> General Tab Check the box as shown and restart the application(AEDT).
      I hope this will help. Please let us know if that resolves your query.
      Vivek
    • Nasser_Mohammadi
      Greetings,
      I am having the same problem. However, i enabled product licensing as noted above, closed and opened the application, and am still having the same problem. Please advise. Here is the msg i am getting:
      Regards ,, Nasser
Viewing 4 reply threads
