September 1, 2022 at 5:19 pm
kemackay
SubscriberHello, I'm attempting to import a custom source to an EME port. The field I'm trying to import is saved from the result of an EME Profile monitor in a previous simulation. The data format I saved this in uses the steps outline in the tutorial here: https://optics.ansys.com/hc/en-us/articles/360034396394-Importing-arbitrary-source-fields-into-EME-ports. I'm able to save the .mat file, import it into the script workspace and view it, and the data appears as it did in the monitor.
However when I attempt to import it to a port (the port has the same dimensions and mesh size as the monitor) I don't get any confirmation, and when I click visualize fields this error pops up. Any help is appreciated.
September 1, 2022 at 6:45 pm
September 1, 2022 at 8:24 pm
kemackay
SubscriberHello, I made a completely new MODE file, with only an EME solver region in the workspace. I took the script provided in the linked tutorial, which creates a sample .mat file of a mode profile. I then click "Import Fields", select the .mat file, press open, and then receive no confirmation. When I click "Visualize data" I get the same error "No mode data was found". Attached is an image showing the script worked and generated a field.
This error occurs on a completely new file with no manipulations done to it, importing a custom source does not appear to work.
September 1, 2022 at 8:57 pm
September 6, 2022 at 2:49 pm
kemackay
SubscriberHi, we upgraded the software to the latest version and it finally worked. Thanks for your assistance.
September 6, 2022 at 2:57 pm
Guilin Sun
Ansys EmployeeThank you for let us know.
- Error on Lumerical device
2598
2080
1317
1108
459
