February 20, 2023 at 7:57 am
Valer TOSA
SubscriberHello,
I try to extract transmission from an EME profile monitor but the answer is that no d-card is available. How can I solve this problem?
Thanks,
Valer Tosa
February 21, 2023 at 6:44 pm
Amrita Pati
Ansys EmployeeHello Valer,
The EME profile monitor collects the E and H fields so, you won't be able to obtain the transmission values from it. The transmission and reflection are automatically calculated and can be obtained from "user s matrix". For more information, please refer to the following video:
https://optics.ansys.com/hc/en-us/articles/360045466773-Running-and-Analysis-Propagating-Interpreting-S-Matrix
It is also important to note that the function "transmission" can only be used in FDTD and varFDTD.
Thank you.
- Error on Lumerical device
3930
2649
1865
1272
610
