May 12, 2023 at 4:38 am
Srinivasa B R
SubscriberHi,
is anyone can guide on how does the Ansys software helps in finding emissions from PCB and to simulate to check wheather product meets the commercial EMC test standard limits.
May 17, 2023 at 8:08 am
Praneeth
Ansys EmployeeHi Srinivasa,
Thank you for reaching out to the Ansys Learning Forum, Your patience is much appreciated.
Did you go through the EMI-EMC example projects under the HFSS design type? If not please go through them and see if they could help you understand the setup.
Best regards,
Praneeth.
- How do I make a chart with multiple material parameters on y-axis?
- Invalid Assignment error
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- How to add SN curve for new material in Fatigue analysis?
- ANSYS 19.0 with Additive Manufacturing Extension
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- Ansys material damage
5122
3223
2433
