June 17, 2022 at 11:55 am
othmandm
SubscriberI have been trying to simulate 3D QLED structures, and I am curious if emission spectra is something that can be obtained in Lumerical? The dipole sources have a spectrum of their own that cannot be altered (as far as I know) so am curious to see if this is possible? -
June 22, 2022 at 4:06 pm
Guilin Sun
Ansys EmployeeFor linear simulation, Lumerical uses normalization to get source-independent result. If you have measured spectrum, simply multiplying it to the simulated transmission you will get the absolute transmission spectrum.
Understanding frequency domain CW normalization -
June 22, 2022 at 4:13 pm
Guilin Sun
Ansys EmployeeThis post does not work properly. The above is one of the 3 answers.
- Error on Lumerical device
3850
2611
1853
1246
600
