Photonics
Photonics
Empty EME parameters after propagation
    • Nathan Lin
      I set up a simple taper structure in the EME solver and added port 1 as input and port 2 as output (TE and TM fundamental modes). Somehow when I click on "eme propagate", the simulation shows blank for all of the cells and s parameters. How do I fix this?
    • Guilin Sun
      Such issue is unusual. Please download an online EME exmaple and test if it works well.
      For your file, to fast test, please use 3 modes instead of 35 , and check modes profiles at each group and see if there is any absormal mode.
      You may need to reboot your compuater; install the latest version.
