October 7, 2018 at 6:43 pm
Raj1996
SubscriberHi. Im currently doing my final year project in Emulsion characterization in a 90 degree bend pipe. Im using VOF method.I need to know if the oil and water is injected or simply put at the at the phase setting.
Thanks in advance.
October 7, 2018 at 9:15 pm
raul.raghav
SubscriberRaj, you set the primary and secondary phases, and define their interaction in the Phases panel. You then prescribe the appropriate conditions at the boundaries through which oil and water would enter and leave. Below are a few video tutorials that would be of help:
Two Phase Fluid Flow Analysis in ANSYS Fluent
October 8, 2018 at 6:04 am
Keyur Kanade
Ansys EmployeeHello,
As shown in tutorials, please patch the volume of fraction before starting iterations.
Also make sure that only one phase enters from inlet.
Keyur
October 9, 2018 at 8:27 am
Ansys EmployeeI would also recommend reviewing the Multiphase chapter in Documentation: specifically the limitations of VOF and it's numerical methods.
Edit: moving to Fluids section too.
October 9, 2018 at 11:34 am
seeta gunti
Ansys EmployeeHi Raj,
might be helpful. Just got the vedio in youtube.
modeling of water -oil emulsion simulation.
Try to connect with him, might get more information about the case set up.
2614
2090
1321
1108
459
