November 19, 2019 at 11:58 am
Sevencool
SubscriberHi,
I am currently working on a parametric study in Workbench 19.0 and 19.2. After I update all the design points and make them run simulations, it is seems that the Workbench update the solutions of these design points one by one. In fact, there are 10 processer in my PC. Then how can I enable it to update several design points simultaneously? Could any one help on this please?
November 20, 2019 at 2:59 pm
Aniket
Ansys EmployeePlease check the "Component Execution mode" in the properties of the parameter set.
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v195/wb2_help/wb2h_submitprojrsm.html
Also note, you may need to have 10 licenses to run the 10 processes parallelly.
-Aniket
November 21, 2019 at 8:58 am
Sevencool
SubscriberHi Aniket,
Thank you very much for the reply.
Unfortunately, it seems that I have to select 'submit to remote solve manager' in the 'Update Option' to enable 'Component Execution Mode'. Currently, I would like to run it on my local PC. Would you think this is OK for my case?
Many Thanks,
Zewen
November 22, 2019 at 4:39 pm
Aniket
Ansys EmployeeI think you'll need ANSYS Design Point Service (DPS) https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v195/dps_ug/dps_overview.html
or
RSM https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v195/wb2_help/wb2h_usingrsmwb.html
You can configure RSM to local machine, but like I said before, you will need 10 licenses to run 10 design points simultaneously.
-Aniket
- Changing of font size
- System Coupling
- 3D ROM in workbench
- ANSYS Workbench Mechanical Solver problem after saving
- ansys with matlab
- Error message “Solver pivot warning” due to element birth and death
- HARDWARE COMPATIBILITY
- System Coupling
- ANSYS Direct Optimization
- When I open the Electronic Desktop, Twin Builder auto opens
5282
3299
2469
