June 29, 2020 at 1:29 pm
Emmanuel001
SubscriberHi
I am trying to model my motor in maxwell 2D environment, after that, I will export to work bench for thermal analysis. I have followed some posts on how to achieve this. But, my challenge is that at the "set temperature effect" option, I can see only "set object temperature", I am not seeing "enable thermal feedback". Please, I need help. Thanks -
June 29, 2020 at 2:37 pm
mchristi
Ansys EmployeeFor 2-way 2D coupling, this is still a beta feature so you need to enable WB options for Beta features.
To do this, go to the WB menu Tools > Options, Appearance, Beta Options. Then the "enable thermal feedback" should appear!
June 29, 2020 at 9:38 pm
Emmanuel001
SubscriberThank you for the quick reply. I did as you said; I enabled the 'beta option', but, the 'enable thermal feedback' is yet to show.
When will I click the beta option? Is it after modelling in Maxwell? Thanks for your time -
July 6, 2020 at 2:04 pm
Emmanuel001
SubscriberThanks so much, I have solved the issue. I observed that the option is not in Maxwell 16 and Ansys 14.5. so, I installed the newer versions (ED 2020R1 and Ansys 2020R1. It has worked!
- Maxwell, HFSS or Q3D?
- Error
3670
2552
1751
1226
582
