Preprocessing
Preprocessing
Topics relate to geometry, meshing, and CAD
Enclosure mesh problem
    • Adam440
    • Keyur Kanade
      This is a complex geometry to mesh for CFD. nYou will need to simplify geometry in SpaceClaim e.g. remove those small holes, close big holes to have correct fluid domain etc. nAlso you will need to define correct sizing. nPlease go through help manual for more details nAlso search this forum, you will get plenty of threads on this issue. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
    • Adam440
      Thank You for your answer. However i?m not computing CFD but harmonic acoustic analysis - i need to get microphone response and compare it to the practical acoustic. But i guess that the process with simplifying geometry will be the same? nRegards,nAdam. n
    • Keyur Kanade
      Yes, you will need to simplify geometry. n
Viewing 3 reply threads
