Enclosure not center
    • NikAsyraf
      Hi, I’m having problem which the enclosure is not center with the VAWT. How do i move the enclosure or the VAWT so that it become centered?
    • NikAsyraf
      when the enclosure is not center, would it possibly affect the simulation afterwards? Because when i create boolean according to some tutorials, there were errors.n
      It may effect the results. I'm not sure why it's off centre, what is the position of the hub axis? It's also an odd configuration for a VAWT, it looks more like a conventional wind turbine. n
