Endplate Steel Connection – Experimental X Ansys Analysis
    • Fabricio.Urquhart
      Hello
      I am trying to do a benchmark, analysing to add in my master thesis. But I am in front of some problems. The epxerimental analysis shows higher stiffness than the FEA Analysis.
      I think that I am doing something wrong, about the value of stiffness factor. I think that is necessary to calibrate this coefficient.
      What do you think about? See the graph below.
    • peteroznewman
      Hello Fabrico,
      Please explain what you mean by stiffness factor.  Is that in the contact definition?
      What is   LIMITE P/ RIGIDA?
      Please insert an image of the model showing loads and boundary conditions.
      Was the material used in the experiment tested to obtain stress-strain data?
      What was the measured thickness of the parts in the experiment?
      Please show an overlay of the experimental material stress-strain curve and the FEA material stress-strain curves.
      I assume the experimental data actually measured force and deflection. If you plot what was measured and overlay the same measurement from the FEA, that is one less source of error.
    • Fabricio.Urquhart
      Hello Peter.
      Yes the stiffness factor in the contact definition. "LIMITE P/RIGIDA" is the graph plotte by Eurocode-3 (2010), I showed it, only to  have the idea, if the connection is rigid or flexible.
      The load applied and the boundary condition you can see in the pictures below:
      The experiment/PHD thesis and the previous work (master thesis) are attached. The material stress-strain curve you can see in page 187 of PHD thesis. The comparation you can see in the master thesis page 172.
    • peteroznewman
      I recommend you perform sensitivity studies on all the factors that you believe have an effect on the curves.
      For example, solve a model with a 20% change in:
      • Normal Stiffness Factor in the Contact definitions
      • Stress values in the Mulitlinear material table
      I anticipate the curve will move very little for the 20% change in Normal Stiffness Factor and it will move much more for the 20% change in the material stress.
    • Fabricio.Urquhart
      Thank you Peter, I will do it.
      I tried to use the values below, recommended ofr Maggi,2004. But with these values, the model does not converge.
Viewing 4 reply threads
