March 23, 2023 at 12:26 pm
ehsan.sadeghi
SubscriberI am using Transition SST SBES turbulence model for a wall-bounded duct flow. I have already calculated the intergal length scale and created a mesh fine enough to capture the small eddies of ineterest. Now I am asked to create a TKE specturm plot for energy cascade. I do the following:
- Calculated resolved TKE = 0.5*(rsme-u^2+rsme-v^2+rsme-w^2). I understand that rsme-u is same u´ is it correct?
- Then for unresolved TKE how can I create a CFF? TKE reported under turbulence is total TKE or unresolved TKE?
- after calculating the total TKE. I use FFT to plot in log-log scale TKE magnitude vs Frquency.
Is it a valid approach?
March 30, 2023 at 2:13 pm
Federico Alzamora Previtali
SubscriberI believe that your approach is correct. TKE reported is the total TKE, from which you can substract resolved TKE to get unresolved TKE.
5250
3299
2469
