energy dissipation
    • salsabeel
      hello every one
      is there a direct  way  to visualize or calculate  energy dissipation in open channel flow simulation that happened  over low gravel dam in fluent cfd, i want to calculate energy dissipation that given by this equation E= y +V^2/2g ,
    • Kalyan Goparaju
      You can create a custom-field function for that equation use the appropriate surface integral operation to get the required value.
      Thanks,
      Kalyan
    • salsabeel
      please ,can you explain more how to custom field function
      best regards
    • Kalyan Goparaju
      Please look at chapter 42.5 of the Fluent 2020 R2 manual. Here is the link to this section.
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/flu_ug/flu_ug_sec_ffunc_create.html?q=custom
      Thanks,
      Kalyan
    • salsabeel
      i cannot access to this link need to customer portal account and i don't have one ,do you have pdf .
      by the way i am using ansys R16.1
      thanks
Viewing 4 reply threads
