energy source – temperature
    • bobd
      Hi all
      I want to study the influence of the heat energy source to my temperature.
      So I have a simple box which is filled with water and put an energy source on the liquid water as on the picture below.
      But if I check my temperature, it is just constant. So I'm wondering if the heat source is actually linked to my temperature or how i can influence my temperature?  Anyone who can help me with this matter?
      Kind regards,
      Bob
    • Keyur Kanade
      check domain - scale and check your problem size limit.
      did you just initialized and checking results?
      make sure you have run enough iterations/time steps to get converged solution.
      Keyur
    • bobd
      I did the mesh check and got following result:
      For the calculation parameters I've put:
    • Keyur Kanade
      please check the domain size with x and y limits. it is in meters.
      if the domain size is correct then make sure you have converged solution.
      Keyur
Viewing 3 reply threads
