April 13, 2023 at 2:51 am
Altair45
SubscriberFor the downloaded example files of Ansys FDTD, I think there are some license limitations.
Through the server with floating license, I ran the files and checked the error like followed image from the .lsf files
So I view the jobs detail, the followed errors appeared. I think it have a problem between main license and floating license.
If anyone can advise on how to fix the problem, I would appreciate it.
(First image is the engine error and second image is the job error -
April 13, 2023 at 3:55 am
Lito Yap
Ansys Employee@Altair45,
Based on the screenshots, these are the same error. You do not have enough FDTD solve license to run the simulation job. 1 solve license allows running 1 simulation job up to a max of 32 cores per job.
> Lumerical solve, accelerator and Ansys HPC license consumption – Ansys Optics
Based on your resource configuration, you are trying to run (-n 4) x (-t 12) = 48 cores.
> Compute resource configuration use cases – Ansys Optics
As indicated in error message - you will need 2 solve license to run the simulation on 48 cores.
To resolve this set your resources to run at 32 MPI processes (-n 32), and always keep the threads to 1 (-t 1). This will run 32 MPI processes on 1 thread each so you will only be utilizing 1 solve license to run on 32 cores/threads on the local computer (localhost).
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5454
3419
2473
1310
1022
