3D Design
3D Design
Engineering Data Source
    • Lewis
      I Really want to understand Mooney Rivlin 2,3,5 and 9 parameters, when to use either one of them.
      What does the documentation say?
    • Lewis
      was doing some analysis for rubber damper and i dont know which model to use
    • peteroznewman
      Do you know the exact specification of the rubber material?  Can you afford to pay to obtain material test data?  If so, obtain a sample of the rubber material that the damper is made of from the manufacturer.  A sheet of that material is one useful shape. There are standard hyperelastic tests that are performed. ANSYS Engineering Data has test data curve fitting programs to obtain the material model coefficients required.
Viewing 3 reply threads
