3D Design
3D Design
Engineering materials
    • Bimark9
      Hello community;
      what material can I get in engineering data to use for the residual space in my geometry that is for visual purposes only not affecting my analysis results?
      or what specifications can i set to create the material that is for visual purpose only
    • Karthik R
      Administrator
      What do you mean by residual space? What type of analysis are you conducting and which tool are you using?
      Thank you.
      Karthik
    • Bimark9
      Hello
      The simulation is a rollover analysis of a bus, according to UN ECE R66 regulation the model should be having a residual space in the passenger cabin.
      The residual space is supposed to be modelled as a void material just used for visual purposes only.
      Am using Andy WB R19.2
      Thank you
