October 27, 2018 at 5:29 pm
sharm2a2
SubscriberHello everyone Do we need to consider y+ value if enhanced wall treatment is used?
If yes,what is the range and if no, please explain.
Thank you
Amit -
October 29, 2018 at 6:24 am
Keyur Kanade
Ansys EmployeeYes, if you have good boundary layer mesh, then please use ewt. For this you may want to get y+ value between 1 to 5.
ewt is used for near wall modeling. It is a two layer modeling with enhanced wall function.
Please see help for further information.
Keyur
Also, please like the answers which have helped you move forward and in the end, once your issue is resolved, please mark the most appropriate solution (most useful advice) as 'Is Solution'. This will help others who are using this thread to find answers to similar questions.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2600
2088
1319
1108
459
