Tagged: engineering-data, fatigue-life, fatique, life
March 17, 2022 at 3:58 pm
MartinGraupner
SubscriberHi all,
how can I enter a "Bilinear S-N Curve" into the Material Properties. Ansys is asking for the First/Second Fatigue Strength Coefficients and Exponents (A, m, C, r).
How can I get these values? I have an S-N curve but I don't know what these coefficients/exponents are supposed to be. I didn't find any explanation or example nor is it explained in the ANSYS Help.
Thanks
March 17, 2022 at 5:02 pmDavid Mercier
You can find fatigue data in materials databases in Granta products (Edupack, Selector, MI) and explanations on the different terms you have to give in Engineering data in Workbench.
Here some calculations explanations from Granta EduPack. So once you have experimental fatigue data, you can try to fit it with such model and then determine the different coefficients.
Regards
Trending discussions- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- Ansys material damage
2688
2138
1355
1140
462
