Environment and Linking issues
    • zwhite
      I am trying to run a UDF on my geometry by get errors about momentum instability. The code can run on another geometry that I have that imports a just a msh.cas file. The code can compile and load but the terminal output is different Ansys' help documentation. I think the environment is not being recognized when I open this model through workbench. How can I get my terminal to output a similar message as Ansys Fluent, in that it resolves the "usage: cl [ option... ] filename... [ /link linkoption... ]"
    • zwhite
      My Ansys terminal output:
      Preparing mesh for display...
      Done.
      Copied C:\Users\me\Downloads\MY_UDF.c to libudf\src
      (system "copy "C:\PROGRA~1\ANSYSI~1\v212\fluent"\fluent21.2.0\src\udf\sconstruct.udf "libudf\win64\3ddp_host\SConstruct" ")
      1 file(s) copied.
      (system "copy "C:\PROGRA~1\ANSYSI~1\v212\fluent"\fluent21.2.0\src\udf\scons_default.bat "libudf\win64\3ddp_host\scons_test.bat" ")
      1 file(s) copied.
      Files udf_names.c and user_nt.udf in 3ddp_host are up-to-date.
      (system "copy "C:\PROGRA~1\ANSYSI~1\v212\fluent"\fluent21.2.0\src\udf\makefile_nt.udf "libudf\win64\3ddp_host\makefile" ")
      1 file(s) copied.
      (chdir "libudf")(chdir "win64\3ddp_host")
      C:\Users\me\Downloads\TryV1_files\dp0\FFF-1\Fluent\libudf\win64\3ddp_host>rem
      C:\Users\me\Downloads\TryV1_files\dp0\FFF-1\Fluent\libudf\win64\3ddp_host>rem Copyright 1987-2021 ANSYS, Inc. All Rights Reserved.
      Microsoft (R) C/C++ Optimizing Compiler Version 18.00.21005.1 for x64
      Copyright (C) Microsoft Corporation. All rights reserved.
      Microsoft (R) Program Maintenance Utility Version 12.00.21005.1
      (system "copy "C:\PROGRA~1\ANSYSI~1\v212\fluent"\fluent21.2.0\src\udf\sconstruct.udf "libudf\win64\3ddp_node\SConstruct" ")
      1 file(s) copied.
      (system "copy "C:\PROGRA~1\ANSYSI~1\v212\fluent"\fluent21.2.0\src\udf\scons_default.bat "libudf\win64\3ddp_node\scons_test.bat" ")
      1 file(s) copied.
      Files udf_names.c and user_nt.udf in 3ddp_node are up-to-date.
      (system "copy "C:\PROGRA~1\ANSYSI~1\v212\fluent"\fluent21.2.0\src\udf\makefile_nt.udf "libudf\win64\3ddp_node\makefile" ")
      1 file(s) copied.
      (chdir "libudf")(chdir "win64\3ddp_node")
      C:\Users\me\Downloads\TryV1_files\dp0\FFF-1\Fluent\libudf\win64\3ddp_node>rem
      C:\Users\me\Downloads\TryV1_files\dp0\FFF-1\Fluent\libudf\win64\3ddp_node>rem Copyright 1987-2021 ANSYS, Inc. All Rights Reserved.
      Done.
      • zwhite
        Ansys help documentation output
        Copied E:\/E:\udfexample.c to libudf\src
        Creating user_nt.udf file for 3d_host ...
        (system "copy C:\Program Files\ANSYS Inc\v212\fluent\fluent21.2.0\src\udf\makefile_nt.udf "libudf\
        win64\3d_host\makefile" ")
                1 file(s) copied.
        (chdir "libudf")(chdir "win64\3d_host")# Generating ud_io1.h
        udfexample.c
        # Generating udf_names.c because of makefile udfexample.obj
        udf_names.c
        # Linking libudf.dll because of makefile user_nt.udf udf_names.obj udfexample.obj
        Microsoft (R) Incremental Linker Version 12.00.31101.0
           Creating library libudf.lib and object libudf.exp
        Creating user_nt.udf file for 3d_node ...
                1 file(s) copied.
        (chdir "libudf")(chdir "win64\3d_node")# Generating ud_io1.h
        udfexample.c
        udf_names.c
        Done.
        Additional Info:
        I open a workbench file that uses the Fluent workbench template in creating a geometry and mesh. Fluent is opened through workbench and I open workbench directly through my start window. The built-in compiler also causes momentum instability with this geometry but not with the independent mesh.cas file.
        Environment variables paths:
        C:\Program Files (x86)\Microsoft Visual Studio 12.0\Common7\Tools
        C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC
        C:\Program Files\ANSYS Inc\v212\fluent\ntbin\win64
        C:\Program Files\ANSYS Inc\v212\fluent\ntbin\clang\lib
        C:\Program Files\ANSYS Inc\v212\fluent\ntbin\clang\10\Include\10.0.18362.0\ucrt
