Ansys Products
Ansys Products
environment variable CFX5ROOT
    • FrankR
      Dear Community,
      happy new year.
      I use FLUENT "Academic Student Release" 19.2 on a Windows-PC.
      I try to get output via "Export to CFD-Post", but the message
      Unable to launch CFD Post from (path not fully displayed, ending in .../CFD-Post/bin/cfx5post.exe)
      Please set environment variable CFX5ROOT and try again.
      pops up.
      Strikingly, I find cfx5post.exe only in a different path:
      C:prgANSYS IncANSYS Studentv192CFXbin
      I am a computer moron and our system administrator is still on holidays.
      How can be problem be fixed ? Where and how do I have to set the environment variable ?
      I am aware that I can disable the Open CFD-Post option, and load the file manually. Would be nice though.
      Your kind assistance is greatly appreciated.
      Regards
      FrankR
    • tsiriaks
      Hi FrankR,
      Normally, you should not need to set any extra environment variable.
      I think there is something off here with the installation.
      Since I don't see the full path that it's trying to launch /CFD-Post/bin/cfx5post.exe , I don't know if this is under the same parent directory as C:prgANSYS IncANSYS Studentv192CFX
      Check this, open CMD Prompt, then type
      set a
      then, see if your ANSYS192_DIR and AWP_ROOT192 are pointing to the correct path (e.g., ANSYS192_DIR=C:prgANSYS IncANSYS Studentv192ANSYS  and AWP_ROOT192=C:prgANSYS IncANSYS Studentv192
      Thanks,
      Win
    • FrankR
      Dear tsiriaks
      thank you. On the command prompt I get
      H:>set a
      ALLUSERSPROFILE=C:ProgramData
      ANSYS192_DIR=C:PrgANSYS IncANSYS Studentv192ANSYS
      ANSYS_SYSDIR=winx64
      ANSYS_SYSDIR32=win32
      ANS_OLD_ATTACH=1
      AWP_LOCALE192=de
      AWP_ROOT192=C:PrgANSYS IncANSYS Studentv192
      cfx5post.exe resides in
      cfx5post.pl resides in
      C:prgANSYS IncANSYS Studentv192CFXbinperllib
      Do you have any other advice ?
      Do not invest too much brainwork: I am aware that I can disable the Open CFD-Post option, and load the output file from FLUENT manually.
      Thanks once more,
      Regards
      FrankR
    • DrAmine
      Can you launch CFD-Post in Standalone?
    • FrankR
      yes
      Regards
      Frank
    • tsiriaks
      Hi Frank,
      On the shortcut that you used to launch stand-alone CFD-Post, right click -> Open file location -> right click on the shortcut and select 'Properties'
      Post the content of the 'Target' here.
      Also try this, open CMD Prompt then use this command
      move %appdata%Ansys %appdata%Ansys.old
      does this make any difference ? If not, post the output of
      set c
      Thanks,
      Win
Viewing 5 reply threads
