December 19, 2021 at 9:48 am
rasslcae
SubscriberWhy in LS-Dyna ACT when I add EOS_LINEAR_POLYNOMIAL to the material, it gives an error:
December 21, 2021 at 9:29 amRam Gopisetti
Ansys Employeeonly selected material models are supported for EOS and they are listed in the manuel-vol-1.
Cheers, Ram
December 21, 2021 at 9:38 amrasslcae
SubscriberYes, i knew, i using aluminium, it is good!
December 21, 2021 at 9:43 amrasslcae
Subscriberwhere can i download this document?I need to know what equations of state can be used for rocks (sandstone, cement)?
December 21, 2021 at 10:53 amRam Gopisetti
Ansys Employeei mean to say the Material model not the type of Material, the manual comes from the installation directory and there are no predefined values for any such material you need to calibrate them or look in the literature.
Cheers, Ram
May 20, 2022 at 5:12 pmgaston
SubscriberHow to model lead material for low velocity impact
Viewing 5 reply threads- You must be logged in to reply to this topic.
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
3778
2587
1831
1242
598
