March 23, 2021 at 3:23 pm
harsf
SubscriberI have modelled a water tank and given an earthquake load to it. For water, I used the Eulerian domain and for the water tank, I used the Lagrangian domain. Sloshing occurs. I am interested to know what equations ansys solves in order to get the results. Can someone help?n -
March 24, 2021 at 3:40 pm
Aniket
Ansys EmployeeWhich tool are you using?n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn -
March 25, 2021 at 12:55 am
harsf
Subscriberhi,n@Aniket , I have attached an image of the model. Actually I didn't get you about the tool, you meant. Can you pls send me some details how to get the equations and solution and the method the programme used to get the solution. Thank you.nn
March 25, 2021 at 7:00 am
1shan
Ansys Employee,nYou could have a look at the explicit dynamics theory guide Chapter 5: Explicit Dynamics Theory Guide (ansys.com) for understanding the equations and the solution methodology. Section 5.2.6. Explicit Fluid Structure Interaction (Euler-Lagrange Coupling) (ansys.com) might be specifically helpful. Also, if you want to simulate sloshing do check out fluid80 (and other similar) elements FLUID80 (ansys.com). Also, have a look at and,nIshan.n
Viewing 3 reply threads
Trending discussions
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
Top Contributors
2524
2066
1279
1096
459
Top Rated Tags
